You are here: FME Server Administrator's Guide > Performing an Express Installation > Express Installation for Windows > Run the Installer
Run the Installer
Run the installer logged in as the user who will be running your FME Server Service.  This user must have write privileges to the installation directory.
Start the installer, and proceed through to the Choose Setup Type prompt. Select the Express option.
Follow the instructions on the screen. We recommend that you use port 80 when prompted. Don’t forget to note the password you enter for the administrator account. On the last screen, click Finish.
Note:  If you already have an existing web server, such as IIS, it is likely to already be using port 80. In that case, turn off IIS or select a different port, such as 8080.
Proceed to Starting and Stopping FME Server.
